Fireman196's avatar
Fireman196
CM1000-100NAS
Purchased this Modem in January. Have had nothing but connection issues with this modem. Called and have had two case numbers assigned to this problem. Nothing resolved. Using Midcontinent Communicat...
  • Fireman196's avatar
    Fireman196
    May 27, 2019
    Antinode,
    Thank you for the suggestion. As you can see, I am a novice at this.
    I ran a new cat 5e line from the cable modem to the R7000, I came out of the R7000 with a line that now goes to the switch. I will try this and see if it resolves the problem. My WiFi router is about 40' from the modem.
    I believe this is what you wanted me to try, let me know if I am incorrect.
    Thanks you again for the replies. Hoepfully this will be the answer.
    Kevin
