sophormoon
Aug 19, 2018Aspirant
CM1000-1AZNAS: IPv6 Setup?
The Netgear Genie screen I am able to access does not seem to offer an option to setup IPv6 even though my cable company supports it. Under advanced, I have options to reset or reboot the router, as...
vkdelta
Aug 19, 2018NETGEAR Employee Retired
CM1000 is a "bridge modem" and not a Gateway/router. It just passed all the DHCPv4/6 transactions from ISP to your Router or laptop directly.
If your ISP supports IPv6, and you connect your laptop directly behind modem, you will get a IPv6 address on your PC
If your ISP supports IPv6, and your router supports IPv6 (and delegated Prefix), you will get a IPv6 address on your PC
you will not find an IPv6 enable/disable option on a modem.
- sophormoonAug 20, 2018Aspirant
Thank you for being gentle with someone who obviously doesn't even qualify as a noob.
I have no idea whether the form in which my "address" is written even matters (security maybe?), but I became aware my ISP supports IPv6 and wondered why I saw no options for it. Full understanding is likely beyond me, but this helps calm my compulsive desire to have the latest and greatest number scheme.
My ethernet cable from the modem goes directly into a single Google Wifi puck (recommended during setup) with the puck's single output to a hub where my other PCs connect. As I mentioned, there is an option to select IPv6 on the puck and my Xbox. Selecting it results in the display showing "IPv4/IPv6" which I gather is the "stack" method or stopgap between now and such time as IPv4 is ever left behind.
Thanks again.
- vkdeltaAug 20, 2018NETGEAR Employee Retired
options in will be in router.
we dont support 3rd party routers but you may want to look at below link on how to enable IPv6 on Google WIFI
https://support.google.com/wifi/answer/6361450?hl=en
- mark814Dec 11, 2018Aspirant
I noticed too that the modem says it doesn't support IPv6. I'm on Cox, who uses it and noticed that if I turn my VPN off and go to an IP test site it reports an IPv6 address for my connection.
