mcbullis08
Sep 10, 2022Aspirant
CM1000-1AZNAS xfinity / download speed issues
Hello all, I am posting here because I am at my wits end with this problem. I have a CM1000 (owned for several years) that has recently started acting up. I pay for the xfinity giga (1200Mbps) se...
Sep 11, 2022Guru - Experienced User
Your power levels look fine.
You don't tell us what router you have connected to the cm1000 and if you're testing directly connecting a pc/laptop to the modem or running through the router.
So, have you connected a pc/laptop directly to the modem to test it?
Or are you running through a router?
