A14
May 28, 2021Aspirant
CM1000 Amber Ethernet
For 6 months I havent had a problem with this modem. I had a storm the other night and my power blinked out, and even tho i have the modem and routers on a UPS, it seems I have a problem now. Th...
May 28, 2021Guru - Experienced User
Try swapping LAN cables...CAT6 is recommended.
Try a different power adapter with same voltage and amps.
A14
I had already tried multiple CAt 5e/6 ethernet cables. I just remembered i had a spare older modem in a drawer. So i plopped it on and after getting it working, in my ErX GUI its showing ful 1000mbps connection. So putting the Netgear modem back on, but using the other power supply. It is still 100mbs. So that leads me to know it is a bad CM1000v2.
- FURRYe38May 28, 2021Guru - Experienced User
Ya sounds like like. :smileyembarrassed:
