GirlB
Oct 14, 2024Aspirant
CM1000 Amber light flashing and low speed but had reset and gotten green and high speed a couple day
I was having slow Internet/Wi-Fi and I reset the modem and then the light was solid green on the bottom and I got 600 Mb per second speed. That was a few days ago and now it’s back to flashing Amber a...
Oct 14, 2024Guru - Experienced User
Whos the ISP your connected with?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
- GirlBOct 14, 2024AspirantEero 6E router. It worked for a few days, which is kind of frustrating.
- GirlBOct 14, 2024AspirantAnd Spectrum internet
- FURRYe38Oct 14, 2024Guru - Experienced User
May need to check with Eero as well for help and information regarding there router product.
Post those two logs when you can.
- GirlBOct 14, 2024AspirantWill do. Although doesn’t the flashing Amber light on the bottom of the modem mean that it’s not connecting to the higher speed network input that we have?
