GirlB
Oct 14, 2024Aspirant
CM1000 Amber light flashing and low speed but had reset and gotten green and high speed a couple day
I was having slow Internet/Wi-Fi and I reset the modem and then the light was solid green on the bottom and I got 600 Mb per second speed. That was a few days ago and now it’s back to flashing Amber a...
Oct 14, 2024Guru - Experienced User
Whos the ISP your connected with?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
GirlB
Eero 6E router. It worked for a few days, which is kind of frustrating.
- GirlBOct 14, 2024AspirantAnd Spectrum internet
- FURRYe38Oct 14, 2024Guru - Experienced User
May need to check with Eero as well for help and information regarding there router product.
Post those two logs when you can.
- GirlBOct 14, 2024AspirantWill do. Although doesn’t the flashing Amber light on the bottom of the modem mean that it’s not connecting to the higher speed network input that we have?
- GirlBOct 14, 2024AspirantAnd when I reset the modem it worked at 600 Mb per second for a couple days and now is back to flashing Amber.
