vincet
Nov 01, 2017Aspirant
CM1000 and COX gigabit not working? any ideas
I have just upgraded to COX gigabit which they have with Docis 3.1 modems like the cm1000, but after they have enabled it and had the tech out they test and get 1G at the cable out of the wall but on...
vincet
Nov 02, 2017Aspirant
they said that had, they have put another modem in temporarily that gives better speed. Can i hook another modem on the network to view the GUI page ?or will that just cause conflict and mess it up ? they are coming back monday next week to review and work on some more
vkdelta
Nov 02, 2017NETGEAR Employee Retired
you can stil connect your CM1000 just to check OFDM is enabled or not. It should not impact your other modem internet connection. just dont connect both the modems at same time.
