GoesByKyle's avatar
GoesByKyle
Follower
Jul 25, 2019
CM1000 and Nighthawk AC1750 show green lights but....
... not getting any connection. Tried to download the nighthawk app and it won't connect to the router at all. I know the internet is working from the modem cause it will work when I am directly connected with a cable. Don't know what to do at this point. Please help, thank you!
1 Reply
  • > CM1000 and Nighthawk AC1750 show green lights but....
       _Which_ lights, on which device, do what, exactly?
    > [...] Tried to download the nighthawk app and it won't connect to the
    > router at all. [...]
       Which "the nighthawk app", running on what?  Have you tried using a
    web browser to talk to the router?
       For each Netgear device, visit http://netgear.com/support , put in
    your model number, and look for Documentation.  Get the User Manual.
    Read.
