Billytheoldman
Jun 23, 2022Follower
Cm1000 and nighthawk x4s. Loose connection to Internet requires a reset to factory default
This problem just started happening when I left my cm1000 modem unplugged for a while and plugged it back it. It could no longer find the network. I think I reset the x4s router and it came back. ...
Jun 23, 2022Guru - Experienced User
The CM1000 is ONLY a modem. There is no built in router.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
What Firmware version is currently loaded on the modem and router?
Try connecting 1 wired PC to the modem and power cycle it. After the modem comes to ready can you get internet services thru the modem on the PC?
Be sure your using good quality LAN cable between the modem and router. CAT6 is recommended.
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
