BigKidDinner
Apr 21, 2020Aspirant
CM1000 and ORBI AC 2200 - Slow Internet
Hey everyone. I have a CM1000 modem and an ORBI 2200 tri-pack set up in my house. I'm experiencing issues with my modem apparently. I have Xfinity 480 mb/s internet but Xfinity is saying they can see...
Apr 22, 2020Guru - Experienced User
The cm1000 is capable of gigabit. I've ran one (and own one) successfully on gigabit with comcast.
If you log into the modem, take a screen snip of your modem's connections page. This shows the connection back to the isp. Take a screen snip and post it back here with your logs.
Also, if you have any splitters, amplifiers, or attenuators remove them from the line.
Preferably, if you can move it. Hook up the modem right where the coax enters the home. this prevents the wiring within the house from being the issue.
BigKidDinner
Apr 22, 2020Aspirant
Is the page you're looking to see? The only splitter I found is the for the cable box and internet.
- plemansApr 22, 2020Guru - Experienced User
no. log into the cm1000 and click on cable connection.
*should* be 192.168.100.1
- BigKidDinnerApr 22, 2020Aspirant
Here's what I have.
Part 2
