Sys
Sep 03, 2019Follower
CM1000 and VOIP plus a security question
Hi, I have a cm1000 with Xfinity service and a mesh wireless router system from another company- things have been working fine as best I can tell over the past year. Today, I wanted to add VOIP fro...
Sep 03, 2019Guru - Experienced User
The CM1000 doesn't support any phone line connection. If you need any kind of phone line support, you'll need a modem that supports that, like the NG CM1150v.
The PW on most modems can be changed and should be changed upon initial installation. Only way PW can be reset is if someone factory reset the modem.
