HankEdwin
Aug 21, 2019Aspirant
CM1000 and Xfinity woes
Greetings, I have been having intermittent recurring issues with what I think is my CM1000 losing connection to Comcast's hardware. I troubleshooted and RMA'ed parts of my home network to see if...
- Aug 21, 2019
Ensure there are no coax cable line splitters in between the modem and ISP service box.
Ensure you using good quality RG6 coax cable between the modem and ISP service box.
Contact the ISP and have them check the signal line and quality up to the modem and check there logs for any disconnections on your line.
Aug 23, 2019Guru - Experienced User
:smileywink:
HankEdwin
Sep 13, 2019Aspirant
Greetings,
I contacted my ISP during one of the outages and they were not able to reach the cable modem at the time. They sent out a crew which replaced the cable pull from the street to my house (8/26 timeframe). Since then, the daily outages are no longer occurring. There is an occasional blip that shows up as can be seen in the attached image post 8/26.
Thanks for the help
- FURRYe38Sep 13, 2019Guru - Experienced User
Glad they were able to fix it.
Enjoy. :smileywink:
