MattA174
Jul 14, 2021Aspirant
CM1000 CM-Status Messages an MDD Message Timeout
Hello, I've been trying to troubleshoot this problem for a couple of days now. I currently have Xfinity as my ISP and recently decided to stop paying $14 monthly for the xfinity modem. I bought a CM1...
Jul 14, 2021Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
- MattA174Jul 14, 2021Aspirant
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency <tabindex=-1>Startup Procedure</tabindex=-1>
Procedure Status Comment Acquire Downstream Channel 399000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv6 only <tabindex=-1>Downstream Bonded Channels (Partial Service)</tabindex=-1>
Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 42 399000000 Hz -5.1 dBmV 41.4 dB 467646725 0 0 2 Locked QAM256 1 453000000 Hz -4.6 dBmV 40.8 dB 466618291 0 0 3 Locked QAM256 2 459000000 Hz -6.3 dBmV 40.6 dB 466621063 5 0 4 Locked QAM256 3 465000000 Hz -7.0 dBmV 40.3 dB 466625586 30 0 5 Locked QAM256 4 471000000 Hz -8.5 dBmV 39.7 dB 466629763 26 0 6 Locked QAM256 5 477000000 Hz -9.5 dBmV 39.4 dB 466633144 21 0 7 Locked QAM256 6 483000000 Hz -10.0 dBmV 38.9 dB 466637072 38 0 8 Locked QAM256 7 489000000 Hz -10.7 dBmV 38.6 dB 466643316 15 0 9 Locked QAM256 8 495000000 Hz -10.5 dBmV 35.4 dB 466646500 46 0 10 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 11 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 12 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 13 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 14 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 15 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 16 Locked QAM256 15 543000000 Hz -11.6 dBmV 30.3 dB 357763593 106025368 2096621 17 Locked QAM256 16 549000000 Hz -10.7 dBmV 36.3 dB 466672312 43 0 18 Locked QAM256 17 555000000 Hz -9.9 dBmV 38.2 dB 466684367 16 0 19 Locked QAM256 18 561000000 Hz -8.4 dBmV 39.7 dB 466697085 1 0 20 Locked QAM256 19 567000000 Hz -7.3 dBmV 38.7 dB 466700960 0 0 21 Locked QAM256 20 573000000 Hz -6.7 dBmV 37.3 dB 466705999 21 0 22 Locked QAM256 21 579000000 Hz -6.4 dBmV 27.2 dB 279485405 18729524 2185855 23 Locked QAM256 22 585000000 Hz -7.0 dBmV 32.0 dB 466705276 6174 0 24 Locked QAM256 23 591000000 Hz -7.7 dBmV 28.4 dB 183873710 55335743 10587227 25 Locked QAM256 38 423000000 Hz -4.1 dBmV 41.5 dB 466678966 0 0 26 Locked QAM256 39 429000000 Hz -3.4 dBmV 41.5 dB 466682307 0 0 27 Locked QAM256 40 435000000 Hz -2.8 dBmV 41.8 dB 466686571 0 0 28 Locked QAM256 41 441000000 Hz -2.7 dBmV 41.6 dB 466690754 0 0 29 Locked QAM256 43 405000000 Hz -5.0 dBmV 41.3 dB 466695004 0 0 30 Locked QAM256 44 411000000 Hz -4.7 dBmV 41.3 dB 466697241 0 0 31 Locked QAM256 45 417000000 Hz -4.4 dBmV 41.5 dB 466700879 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 1 35600000 Hz 52.5 dBmV 2 Locked ATDMA 2 29200000 Hz 54.3 dBmV 3 Locked ATDMA 3 22800000 Hz 55.0 dBmV 4 Locked ATDMA 4 16400000 Hz 55.5 dBmV 5 Locked ATDMA 5 39600000 Hz 49.8 dBmV 6 Not Locked Unknown 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Hz 0.0 dBmV <tabindex=-1>Downstream OFDM Channels</tabindex=-1>
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0, 1, 2, 3 37 722000000 Hz -13.3 dBmV 20.5 dB 1228 ~ 2867 168265294 26179906 142083493 2 Not Locked 0 0 0 Hz -5.5 dBmV 0.0 dB 0 ~ 4095 0 0 0 <tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked Unknown 0 0 Hz 0 dBmV 2 Not Locked Unknown 0 0 Hz 0 dBmV Current System Time: Wed Jul 14 23:02:36 2021 System Up Time: 2:51:53
I will contact my ISP tomorrow and will give an update here.
- FURRYe38Jul 15, 2021Guru - Experienced User
Ask them why channels 10 thru 15 are not locked in...I believe they should be.
- plemansJul 15, 2021Guru - Experienced User
Your power levels are all over the place and you have a ton of errors.
Make sure to remove anything from the lines including splitters, signal attenuators, amplifiers.
Check for kinks, bad connections, old/corroded/cheap connectors and cables. remove them if you do.
Preferrably, move the modem to right where the coax enters the home to prevent wiring internal to the home being the issue.
Many isp's will charge you for fixing a wireless problem inside the home.
then try it.
- vkdeltaJul 16, 2021NETGEAR Employee Retired
your line is quite messed up. ISP needs to really fix TONs of Uncorrectable errors and multiple channels not able to sync as well.
