nephilimreborn
Jul 13, 2017Aspirant
CM1000 Compatibility with Wave Broadband in WA
I recently purchased the Netgear CM1000 for use with my 250Mbps service with Wave Broadband, however they cannot seem to activate it with their service at this time despite that the same unit is comp...
nephilimreborn
Jul 14, 2017Aspirant
Is there a way I can collect an event log? I simply connected the modem and everything powered on, but when Wave tried to add the device they could not communicate with it and stated they did not have the firmware to be pushed to the device. I know their device list is limited, but they did say they work with alot of products, they just did not have the firmware to push to the device yet.
Thanks for your original reply.
vkdelta
Jul 15, 2017NETGEAR Employee Retired
NETGEAR can provide FW to Wave broadband. Just PM me their engineers name/email addresses.
Wave needs to be willing to push the FW though.
however, this does not seem to be FW issue if the modem does not even come up on the network.
NOTE: DOCSIS 3.1 REQUIRES MSO NETWORK TO BE DOCSIS 3.0 complaint (including US channel bonding).
1. What FW version are you on?
2. Login to modem 192.168.100.1 and capture event logs and power levels.
https://kb.netgear.com/30008/How-do-I-obtain-the-event-logs-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
- nephilimrebornJul 15, 2017Aspirant
I just PM'd you. They are willing to push it and have been notified that it will be coming.
I will gather the other info you requested when I get home later today.
Thank you very much
- jaaymondoJul 16, 2017Aspirant
nephilimreborn has this been resolved? I am buying a modem for new service being installed on Friday. Considering the Netgear CM1000, Arris SB8200, or Motorola MB8600. Just called Wave and they said they dont support any netgear modems.
- nephilimrebornJul 18, 2017Aspirant
Hate to break this to you, but DO NOT get the Netgear CM1000. Wave does not support Netgear products and they refuse to get the firmware and other info the Netgear techs are willing to provide. I ended up returning this product and picked up an Arris 6190. Not Docsis 3.1, but will still support a Gigabit connection when its available.
