fbachmann3
Jun 03, 2020Aspirant
CM1000 Connection Drops
I've seen a few other posts with similar issues but I believe the log messages I'm seeing on my modem are different so I'm starting a new post. For months, I've been having intermittent connectio...
Jun 03, 2020Guru - Experienced User
You might get you another modem, say from amazon and try out this other modem to see if it also experiences the same problems or not, if not, then you'll know it's the CM1000.
