b00tn3t
Apr 16, 2020Follower
CM1000 Cox Gigablast
Hi, i've had my CM1000 for a few months now and i just recently upgraded to Cox Gigablast. I have an issue where when i am connected directly to the modem, i'll have one test that'll be the right dow...
Apr 16, 2020Guru - Experienced User
CAT6 would be minimum and try a different wired PC to compare results if possible.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
