NoLegs
Oct 31, 2019Tutor
CM1000 Dynamic Range Window issues
Cox is no help, how do I troubleshoot Dynamnic Range Window issues when my power levels are near perfect? Everything is new from the street to the modem. Path from street = NEW RG6Q to dmarc w...
NoLegs
Oct 31, 2019Tutor
I guess I attached the event log twice.
Nov 01, 2019Guru - Experienced User
Are you having problems with your internet? Is it dropping, increased ping/lag, slowed speeds? Whats the actual problem? Because your power levels are indeed pretty close to perfect and you have a single error. 1. that looks like a great connection.
- NoLegsNov 01, 2019Tutor
My connection is a roller coaster with Cox. As of this moment, yes, this is the only error. Last weekend it was severe packet loss, T3/T4 errors. Sometimes I'll go days without any errors at all and my power levels are just like you see here.
I guess what I'm really looking for is an explanation on what a Dynamic Range Window error is...because the definition I find does not coorelate to what my power levels are. So why is the modem reporting this issue when it's obvious that there is not one?
FYI, my neighbor's Arris SB8200 reports similar errors when his window is also not out of range. We are connected to two sides of the same tap at the street.
- plemansNov 01, 2019Guru - Experienced User
dynamic range window violations occur when there's more than a certain variation in the power levels. Hard part is that when you pull the connections page is that it takes the snapshot at the time you access it. If the error is brief, you'll miss the variation when you pull up the page.
If both you and your neighbor are getting these errors, I'd have your isp inspect your neighbor hood box/lines. If its a single user it tends to be from the box to the users house but if multiples are getting it, something else is causing the problems.
- NoLegsNov 02, 2019Tutor
Out of curiosity, I removed the 6db pad from the line and I haven't had a single DRW error since, but (obviously) my rx levels have increased to ~6-7dBmV and my tx power is now sitting at~37dBmV. Should I attempt a different brand pad to get my levels at a more optimum level or run the modem as is?
