mustafa__0321's avatar
Apr 07, 2020
CM1000 ethernet flashing orange
So I just replaced my router and modem today and the modems ethernet led has been flashing orange all day but my router is solid green and my connection seems to be stable is there something i can tr...
  • plemans's avatar
    Apr 07, 2020
    What router are you connected to?
    Have you checked your cable?
    if you read the manual, if the ethernet port light is blinking, it means its passing traffic. Green is 1000mbps link rate and amber is 100mbps link rate.
    https://www.netgear.com/support/product/Cm1000
