RGLawson
Feb 22, 2021Aspirant
CM1000 Event Log Error Messages
Where can I find information about the error messages in my event log? I've been having intermittent internet problems over the past week, so I checked the event log. One entry for today is: DHCP REN...
Feb 22, 2021Guru - Experienced User
post the full event logs and the cable connections page. Those in conjunction together lets us check your line.
(a screen snip is easier to read)
- RGLawsonFeb 22, 2021Aspirant
Thanks for your help. I've attached snips of the event log going back several days, along with the cable connection page.I've combined the snips into a PDF, but please let me know if there is a better way to share that.
Does any of that show anything helpful?
- plemansFeb 22, 2021Guru - Experienced User
You missed channel 17-24. So not sure about those channels.
Your upstream power is really low. It should be >37 and you're lower than that.
Your logs also indicate a line issue.
I'd check your line for amplifiers, signal attenuators, or splitters. Check the line for damage, kinks, old/bad/damaged/loose connections
Thanks - I'll check the line. I know there is a splitter because the co-ax originally got split to three lines for three areas of the house. Since the coax only needs to go to the modem, there is probably a more direct way to connect things.
Would the low power upstream lead to intermittent problems, or is that more likely due to a bad cable connection somewhere?
