sambeaux254
Sep 12, 2018Guide
CM1000 firmware updates
In working on some connectivity issues that I have documented in another thread (re the x10 requiring frequent reboots), I discovered that my CM1000 was running on old firmware (V2.01.15). Netgear's website shows the current firmware as V3.01.04. Netgear's website indicates that modem firmware can only be updated by your ISP. My ISP, Grande Communications, has a policy that it will not push out firmware updates for customer-owned modems. I cannot locate an option, if one exists, that would allow me to directly download the update, and trying to contact Netgear for support is like chasing a rainbow. Changing my ISP is not an option. Ideas?
- DarrenMSr. NETGEAR Moderator
You can not manually update the firmware the isp will push this to your modem.
DarrenM
DarrenM thank you for the reply. If you'll read my original message, however, my ISP (which I can't change), by policy, will not push out firmware updates for devices owned by the customers (not leased from the ISP). It's a stupid policy, because they could easily slap together a robust indemnity agreement that would preclude me from blaming any resulting problems on them, but I'm stuck with it.
For Netgear's part, why is this not customer-downloadable content? Just about every other firmware-driven device in the world allows customers to directly download updates. Seems bull-headed.
Its not Netgears fault this is apart of the docsis standard every company that makes cable modems has to send there firmware to the ISP and have them approve the firmware and then the ISP pushes the firmware when they want to.
DarrenM
