Amdahl
Feb 16, 2022Tutor
CM1000 firmware upgrade - TDS telecom
Lookng for a firware upgrade, my Telco says they don't support this 'TDS Telecom'. How do i get hold of the latest firmware to self help here. I have contacted them already(TDS telecom), but not over...
Amdahl
Feb 16, 2022Tutor
Hi,
Thanks, I've already asked my Provider and will go back again . What if my provider wont do this ? becuase it cost them money/huge support costs..., then what do customers do ?, they already told me this verbally so now i'm going back in writing.
There is a bigger story at play here, we already went through a BYOD for enterprises, now this is basically the same due to integration of Cable Modem/Router/Wireless integration in a box... if it's my cable/router box then i have to have the ability to manage that, the telco provides the physical termination to the CPE and stops there. Given this, IMHO I'd strongly advise Netgear to NOT go through the Telcos for this aspect as it puts them at an interesting point of being blocked through long cycles of validation to put products/fixes onto the said networks and bring new features. I've been through this with Cisco/Juniper when working there with Major Telcos, it can be a slippery and very expensive slope.
Feb 16, 2022Guru - Experienced User
Amdahl wrote:
Hi,
While we agree with this principle, the problem is that its part of the Docsis spec. So the modem side of it, the ISP is the only one who can push the firmware to it. The newer combo devices like the CAX30/80 have dual partitions. One for the modem side and one for the router side. so you can upgrade the router side but the modem side is still controlled by the ISP. Its not something a single provider can change. Again as its part of the docsis spec.
