Amdahl
Feb 16, 2022Tutor
CM1000 firmware upgrade - TDS telecom
Lookng for a firware upgrade, my Telco says they don't support this 'TDS Telecom'. How do i get hold of the latest firmware to self help here. I have contacted them already(TDS telecom), but not over...
Feb 16, 2022Guru - Experienced User
As plemans mentioned, this has been the DOCSIS spec for years. Mainly came from historical problems when ISP pushed untested or bugged FW updates to user owned modems and there modems no longer worked or became bricked. This ISP incurred replacement expenses to replace the user owned modems. So the spec now calls for ISPs are resposible to test and certify ANY fw that comes from modem Mfrs prior to pushing to modems. They also have the ability to not push to user owned modems as well by choice. So users have the choice to use there own modems, if and where they are supported BY the ISP, or use the ISP modems they offer and ISPs have the choice to push FW updates to users owned modems or NOT. Policies regarding this varies per ISP. Some may, some may not. Again, been like this for years. Its not a modem MFrs choice, its the "Spec!"
And not changing anytime soon I would presume.
Good Luck.
Amdahl
Feb 17, 2022Tutor
5.2.3 Cable Modem Secure Software Download
To download a CM software image securely, the CM vendor and/or MSO will digitally sign the image using the
appropriate code verification certificate (CVC) and place the image on a Software Download server. A CM is
enabled to download a software image when it receives a valid CVC in its configuration file. Triggering the
download of the software image can be done using parameters in the CM configuration file, or SNMP commands.
After a CM downloads a software image, it validates the image by verifying that the included CVC chains to the
Root CA Certificate trust anchor, and by checking...
https://www.cablelabs.com/specifications/CM-SP-SECv3.1
The CM Vendor is Netgear here. So, DOCSIS3.1 and the Security spec. clearly allows the Vendor to provide this Software but ddoes not say Firmware(to split hares!!).
While agreeing that Bricking my Device is a possibility, it is on the users, no harm and no foul in court. However folks like Netgear SHOULD or MUST valdate the software with the said provider would be a good option.
Thanks, have re-pinged my provider again.
- FURRYe38Feb 17, 2022Guru - Experienced User
Thats all again, up to the ISP to push that.
Good luck.
