gmx94
Oct 23, 2019Aspirant
CM1000 Gigabit Speed Issues
I recently bought the CM1000 modem and the AC1750 R6400v2 router. I just upgraded to Cox Gigablast speeds about a week ago. The speeds I'm suppose to be getting are around 940 Mbps. When I run speed t...
Oct 23, 2019Guru - Experienced User
Have you directly speed tested with a wired PC connected to the CM modem?
You router may not be capable of passing thru with anything near 900Mbps...
- gmx94Oct 23, 2019AspirantAlready tried that. Only got speeds of about 550 to 600 Mbps. Sorry, I wasn't clear enough in the first post.
- FURRYe38Oct 23, 2019Guru - Experienced User
Try a different PC to compare speed with the modem?
You might contact the ISP and have them check the signal quality up to the modem.
Be sure there are not cable coax line splitters in between the modem and ISP service box.
