Scotterdude's avatar
Scotterdude
CM1000 has slow or fast blinking of "internet" LED
Like the title says...
Occasionally, more often when it's windy, the ethernet light will go solid, and the "internet" light, will either blink slowly, or quickly. At that time, no internet is will work. The modem will reset, sometimes a few times, and it will eventually reconnect correctly. However, sometimes that is a 30 minute event.
Here are the logs!
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    You may want your ISP tech to come to check out the cable lines if you are noticing the internet dropping when bad weather happens.
    DarrenM
