AverageJoe88's avatar
AverageJoe88
Cm1000 health check
I don't know what any of this means. Can someone please tell me if everything looks good or should I schedule a tech to come check things out.
    • plemans's avatar
      It means your power levels are half way decent. They're a little out of spec as the downstream should be within 3.5dbmv of each other. They just a little bit out of that but you're not showing any errors in the line.
      are you having issues?
      • AverageJoe88's avatar
        AverageJoe88
        no issues streaming movies or web surfing, but when i’m gaming something feels off. i get a lot of micro stutters during gun fights in apex legends, my fps will drop. i have the cm 1000 and xr500. everything looks good on my end. i have gig speeds. with no packet loss. could the out of spec power levels be the reason for this? from the main drop it’s hooked up to a ground block, from there i have it connected to a poe filter directly connected to a 2 way splitter. then i have a coax running to modem and the other to dvr box.
  • Yes I am facing the same confusion about it and looking to take guide about the health issue I watched some sites but did not find the right solution thats why I am here to take guide.
