LooseNut's avatar
LooseNut
CM1000 Installation/Setup Question
Hello Group, I am planning to upgrade my cable (Xfinity) modem, and eventually bump up to the gigabit plan. I have a question that I hope someone can answer. Will the netgear cm1000 (DOCSIS 3.1...
  • plemans's avatar
    Mar 17, 2019
    Yes, the cm1000 will have no problems with slower service. Itll run 150mbps fine.
