Yamuchee
Feb 24, 2021Aspirant
Cm1000 internet problem
it's been 8 months since I had this modem and today it decided to stop working. called Cox and they say it was good on their end. called netgear and they say it might be my modem that's the issue. the...
antinode
Feb 24, 2021Guru
> [...] called netgear [...]
How, exactly? Did you contact Netgear, or some scam outfit who
claimed to offer "support" for your Netgear device?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions and "Troubleshoot"?
Yamuchee
is the legit person. I'm just confuse that if the device is not broken I could've reboot/reset it.. I tried unplug, nighthawk reboot, going to admin genie site to reboot and there seems to have no connection. I don't know what I'm looking for to be able to reset it myself. I'll definitely look at those links. any suggestion will help.
- FURRYe38Feb 24, 2021Guru - Experienced User
Be sure to check the other suggestions as well. Ask the ISP about this as well. Ask a friend for family member to help you out if needed that may have more experience.
Good Luck.
