Ghery
May 28, 2018Aspirant
CM1000 is not talking to routers over Ethernet
I bought a CM1000 from Best Buy this afternoon. This is to replace a Motorola cable modem I've had for a number of years with something faster. After a bunch of fooling around with Comcast the CM10...
antinode
May 28, 2018Guru
> [...] After a bunch of fooling around with Comcast [...]
Not much meat on that bone.
> [...] It is not, however, talking to my network. [...]
And how would it do that? Through some (unspecified, secret(?))
router or other?
> [...] The Ethernet light is red unless only a single computer is
> connected. [...]
Any "a single computer", or one specific "a single computer"?
https://community.netgear.com/t5/x/x/m-p/1574972
- GheryMay 28, 2018Aspirant
Snarky replies aren't very helpful...
"talking to my network" means just what you suppose it means - through the Ethernet connection. Connect it to either router or the switch and you get a red light. Connect the cable modem directly to the laptop I'm using and you get a green light. Red light = no joy in communicating with anything over Ethernet.
- antinodeMay 28, 2018Guru
Not answering specific questions is what's really unhelpful in these
situations. Along with information-free problem descriptions.
> [...] Connect it to either router or the switch and you get a red
> light.
Still wondering what that mysterious "router" might be,
And what is your "the switch"? Connecting a modem directly to a
network switch would very likely cause trouble with multiple client
devices. Why involve it, whatever it is?
> [...] Connect the cable modem directly to the laptop I'm using and you
> get a green light. [...]
Yeah, I got that the first time. Hence the other (still unanswered)
questions.- GheryMay 28, 2018Aspirant
Cable Modem -> Router (provided by Comcast) -> Router (provided by me) -> Gigabit switch.
Various computers are connected to the second router and the switch, either via Wifi or Ethernet for the router and Ethernet for the switch. The first router provides WiFi connectivity for the Comcast security system and nothing else. Breaking the chain and connecting any of the routers or switch to the cable modem results in the light going red. Connecting a computer directly to the Ethernet port on the cable modem results in a green light and communications.
Removing the CM1000 and replacing it with the old Motorola cable modem results in communications for all devices tried so far.
This help?
