RiveraHH1518
Feb 27, 2020Follower
CM1000 Issues
Hello, Today I went out and purchased the Netgear CM1000 modem to replace the Panoramic WiFi rental from Cox. I currently am on their Gigablast service but I am far from a "Gig" and even further fro...
Feb 27, 2020Guru - Experienced User
we also need to see the rest of your download channels on a screen snip.
You'd paid for gigabit using their box and weren't hitting gigabit speeds? Did you try troubleshooting prior to buying a new modem?
Any splitters, amplifiers/attenuators in line? If so remove them.
Also preferably, move the modem right where the coax enters the home. this prevents issues with wiring within the home causing line problems.
did you report this to cox prior to buying the CM1000 to have them check your line and make sure your area was capable of hitting gigabit or getting gigabit to your rented box?
