AverageJoe88's avatar
AverageJoe88
cm1000 issues
  • plemans's avatar
    What issue are you having?
    More details are going to help.
    You didn't get all the channels in your post but the ones you did, look pretty good.
    • AverageJoe88's avatar
      AverageJoe88
      i have xfinity gig speeds but i’m not getting what i’m paying for. i’ll run a test and get somewhere around 800+ download. then i’ll run another speed test and it will drop into the 500. upload test will spike up to 40mbps then it’ll drop down into the 10’s and slowly crawl back up to 40. my speed test are inconsistent. i checked the logs on the modem and i’m getting SYNC timing synchronization failure and no ranging response received-t3 timeouts. how do i fix this
