Albertxwtf
Jun 26, 2022Aspirant
CM1000 keeps rebooting blinking downstream light
Context: I’ve had the CM1000 for a few years at this point and today about an hour ago I noticed I was having wifi issues, I went to go check my modem and router (CM1000 and Nighthawk AC2600 respectiv...
Albertxwtf
Jun 27, 2022Aspirant
Update: it fixed itself somehow. It just started working again idk
- FURRYe38Jun 27, 2022Guru - Experienced User
I recommend posting a screen capture of the cable connections page from the modem here so we can take a look at the signal levels on your modem. Possible they maybe slightly out of spec which could cause the downstream light to blink.
