Davejp
Oct 05, 2019Tutor
cm1000 keeps rebooting
CM1000, Firmware Version V5.01.04, Windows 10 I started getting the following event log errors yesterday. Modem kept restarting. Seems to have cleared itself this morning? anyone have an idea what...
Oct 06, 2019Guru - Experienced User
Contact your ISP and have them check signals up to the modem.
Be sure there are no coax cable line splitters in between the ISP service box and the modem.
Davejp wrote:CM1000, Firmware Version V5.01.04, Windows 10
I started getting the following event log errors yesterday. Modem kept restarting. Seems to have cleared itself this morning? anyone have an idea what these are?
2019-10-04, 21:46:49Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=14:59:c0:f4:28:e0;CMTS-MAC=84:8a:8d:32:2b:1f;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedCritical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:f4:28:e0;CMTS-MAC=84:8a:8d:32:2b:1f;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedCritical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=14:59:c0:f4:28:e0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
- CrazytekkieNov 28, 2019AspirantActually your is has nothing to do with it rebooting constantly. Mine is doing it also but I can tell you for sure, you should be able to completely disconnect your cable altogether and still be able to log in to the router without it rebooting and with cable completely disconnected.
