Brian88195
Jul 07, 2020Aspirant
Cm1000 lan connector not working
Cm1000 modem where the power, down/upstream and internet light are all solid green. The lan light is off. Rebooted and reset the modem, changed cables and connected a laptop directly to the modem.
Jul 07, 2020Guru - Experienced User
Does wiggling the lan cable while plugged in do anything. Thought maybe the connector on the modem could have come loose.
Directly connected with a wired PC?
If nothing seens to bring the connection LED alive, the modem maybe bad.
- Brian88195Jul 07, 2020AspirantTried wiggling the cable and that didn’t work. Connected to a laptop and no difference. Called Netgear and did all of the tips they had. They came to the conclusion that my 14 month old router needs to be replaced. So I replaced it with an ARRIS one.
- FURRYe38Jul 07, 2020Guru - Experienced User
Good Luck.
