net1a
Oct 08, 2021Aspirant
CM1000 Lost Internet
On October 2nd 2021 my interntet stopped working. No device in my home can conect to the internet. I had Comcast come out and they told me the signal is going into the modem but nothing is comming ...
Oct 08, 2021Guru - Experienced User
If you connect a wired PC to the CM modem and power it off for 30 seconds then back ON, after it seems ready can you access the modems web page at 192.168.100.1 at all in a web browser?
- net1aOct 08, 2021AspirantWhen I did that it worked. Now I have Internet if I plug the modem directly into a device but when I plug it into my router I get nothing through it. The router is a nighthawk R700P phones and tablets say couldn't get ip address or no internet
- plemansOct 09, 2021Guru - Experienced User
power off both the modem and the router. Leave them off for 2 minutes. Make sure nothing is connected to the ethernet ports on both.
then power on the modem and give it a couple minutes to fully boot
connect its lan cable to the wan port on the router.
boot up the router and give it a couple minutes to fully boot.
See if the router works.
- net1aOct 11, 2021Aspirant
Thank you for your response. I tried what you said and still have the same results. Device can connect to the wifi but no internet connection. When I plug a computer directly into the modem it works.
