net1a
Oct 08, 2021Aspirant
CM1000 Lost Internet
On October 2nd 2021 my interntet stopped working. No device in my home can conect to the internet. I had Comcast come out and they told me the signal is going into the modem but nothing is comming ...
net1a
When I did that it worked. Now I have Internet if I plug the modem directly into a device but when I plug it into my router I get nothing through it. The router is a nighthawk R700P phones and tablets say couldn't get ip address or no internet
Oct 09, 2021Guru - Experienced User
power off both the modem and the router. Leave them off for 2 minutes. Make sure nothing is connected to the ethernet ports on both.
then power on the modem and give it a couple minutes to fully boot
connect its lan cable to the wan port on the router.
boot up the router and give it a couple minutes to fully boot.
See if the router works.
- net1aOct 11, 2021Aspirant
Thank you for your response. I tried what you said and still have the same results. Device can connect to the wifi but no internet connection. When I plug a computer directly into the modem it works.
- FURRYe38Oct 12, 2021Guru - Experienced User
Sounds like your wifi router needs looked into. Contact the Mfr support for help and information regarding there product.
- plemansOct 12, 2021Guru - Experienced User
what firmware is on the R7000P?
are you able to log into it and access it?what are the led's on it doing?
- net1aOct 14, 2021Aspirant
not sure what firmwear version it has, i can not log in to it. All the lights are showing good white/blue
