franklioxygen
Nov 11, 2021Tutor
CM1000 MDD message timeout
My ISP is xfinity, they said nothing wrong from their end. They send some signal not receiving proper response. I found this in the log: Can someone let me know it's device or wire issue? ...
- Nov 11, 2021
you can check for bad ends/loose connections.
If there isn't any, then they would need to check the line
Nov 11, 2021Guru - Experienced User
Any splitters, amplifiers, or signal attenuators in your cable line? If so remove them.
Preferably, move the modem to right where the coax enters the home. This prevents wiring/connections in the home from being the issues.
If that isn't an option, check the coax cable for kinks, damage, old/bad/cheap/corroded connections and remove them if you have them.
franklioxygen
Nov 11, 2021Tutor
Thanks for replying,
It is the coax enters the home. No splitter or anything else.
I might need ask technician to come.
