franklioxygen
Nov 11, 2021Tutor
CM1000 MDD message timeout
My ISP is xfinity, they said nothing wrong from their end. They send some signal not receiving proper response. I found this in the log: Can someone let me know it's device or wire issue? ...
- Nov 11, 2021
you can check for bad ends/loose connections.
If there isn't any, then they would need to check the line
franklioxygen
Nov 11, 2021Tutor
Thanks for replying,
It is the coax enters the home. No splitter or anything else.
I might need ask technician to come.
Nov 11, 2021Guru - Experienced User
