Tjpereny
Jan 24, 2023Aspirant
CM1000 Modem Blinking Downstream Light
I recently bought this modem to try and help solve some connection issues I was having. My problems have compounded and my main problem is an excessive amount of packet loss ranging from 10-30%. Comca...
Jan 25, 2023Guru - Experienced User
You have errors in your lines and your power is quite a ways out of spec. Its tough to use the log because you only captured 6 minutes of it. I have a feeling there's quite a few errors in the logs but there isn't enough of them.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
If that doesn't help, the isp needs to check th elines.
