cheesesteaks
Aug 28, 2017Aspirant
CM1000 modem comcast gigabit - slow speed
Got comcast gigabit service. comcast replaced outside and inside lines and tested the signal strength which they told me was good - in fact in the sweet spot. I haven't been able to get more than 3...
Stutex
Aug 29, 2017Initiate
Your problem is the exact same one as mine. I am hoping someone will be able to figure it out so I don't have to return the modem. If you do figure out how to solve the problem, can you let me know or make sure you post the solution?? I have spent so much time on this and am so frustrated. THANKS!!!
