cheesesteaks
Aug 28, 2017Aspirant
CM1000 modem comcast gigabit - slow speed
Got comcast gigabit service. comcast replaced outside and inside lines and tested the signal strength which they told me was good - in fact in the sweet spot. I haven't been able to get more than 3...
wgdunlap
Dec 04, 2017Tutor
I have the same issue. I activated my CM1000 with Comcast today on their Gigabit service. I can’t get more than 378 megs out of this thing. Looks like it’s going back to Amazon.
MattEg
Mar 07, 2018Initiate
Was a resolution to this issue ever found? I have the EXACT same problem with Xfinity and the CM1000. I am starting to think it;s the modem and am likely to return it and instead just use the Xfinity supplied modem (which is NOT what I want to do)
- wgdunlapMar 07, 2018TutorFor me, the only resolution was to use the Comcast modem. I even tried the Arris Surfboard Gigabit modem and got the same result. The problem is definitely somewhere on Comcast’s provisioning end.
- cheesesteaksMar 08, 2018Aspirant
The best I've been able to get is 470 mbs at firmware version V3.01.04. Just curious what you were getting with the Netgear and Arris?
Looking at https://mydeviceinfo.xfinity.com/customerinfo I find under my 'download speed' 789.2 mbps shows as 'My plan speed' not 1000 mbps. Not sure if this points to some issue.
- TurretGamingApr 19, 2018Aspirant
Its no doubt comcast cause they want you to use their modem and pay per month
