cheesesteaks
Aug 28, 2017Aspirant
CM1000 modem comcast gigabit - slow speed
Got comcast gigabit service. comcast replaced outside and inside lines and tested the signal strength which they told me was good - in fact in the sweet spot. I haven't been able to get more than 3...
wgdunlap
Mar 07, 2018Tutor
For me, the only resolution was to use the Comcast modem. I even tried the Arris Surfboard Gigabit modem and got the same result. The problem is definitely somewhere on Comcast’s provisioning end.
cheesesteaks
Mar 08, 2018Aspirant
The best I've been able to get is 470 mbs at firmware version V3.01.04. Just curious what you were getting with the Netgear and Arris?
- cheesesteaksMar 08, 2018Aspirant
Looking at https://mydeviceinfo.xfinity.com/customerinfo I find under my 'download speed' 789.2 mbps shows as 'My plan speed' not 1000 mbps. Not sure if this points to some issue.
- MattEgMar 09, 2018Initiate
Yeah, mine shows 986.50 as "plan speed" but I'm not evern getting that.
- wgdunlapMar 08, 2018Tutor
The best speed I reached with the CM1000 was 450, and with the ARRIS it was 500. I had one Comcast tech tell me that Comact's servers would only support around 450 and that was the best I could expect. I didn't buy that. Why sell gigabit service if you never break 500? However, when the second tech came out and hooked up the Comcast modem, I consistently got speeds of 800-940. I hate using Comcast's modem, but for now, its the only way I can get the speeds I am paying for.
