DanITGuy
Jul 05, 2024Aspirant
CM1000 Modem error logs please help troubleshoot. Cox 2GB internet speed dropping
Please help me troubleshoot this issue. Cox 2G internet keeps dropping from 400 mbps to 20 to 30 mbps, and bouncing. All SNR is above 40dB. All channels are locked. Attached the error log. HELP?
Jul 05, 2024Guru - Experienced User
You didn't include much of your logs. A brief piece of it. More would be needed and a copy of the cable connections page. those are used in conjunction.
the little bit you included of the logs are showing line issues.
DanITGuy
Time Priority Description
2024-07-05, 08:12:19 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=14:59:c0:f4:12:10;CMTS-MAC=34:f8:e7:58:04:e9;CM-QOS=1.1;CM-VER=3.1;
2024-07-05, 08:11:48 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=14:59:c0:f4:12:10;CMTS-MAC=34:f8:e7:58:04:e9;CM-QOS=1.1;CM-VER=3.1;
2024-07-05, 03:04:01 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=14:59:c0:f4:12:10;CMTS-MAC=34:f8:e7:58:04:e9;CM-QOS=1.1;CM-VER=3.1;
2024-07-05, 03:03:28 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=14:59:c0:f4:12:10;CMTS-MAC=34:f8:e7:58:04:e9;CM-QOS=1.1;CM-VER=3.1;
2024-07-05, 00:16:35 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=14:59:c0:f4:12:10;CMTS-MAC=34:f8:e7:58:04:e9;CM-QOS=1.1;CM-VER=3.1;
2024-07-05, 00:16:17 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=14:59:c0:f4:12:10;CMTS-MAC=34:f8:e7:58:04:e9;CM-QOS=1.1;CM-VER=3.1;
2024-07-04, 21:58:17 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=14:59:c0:f4:12:10;CMTS-MAC=34:f8:e7:58:04:e9;CM-QOS=1.1;CM-VER=3.1;
2024-07-04, 21:57:48 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=14:59:c0:f4:12:10;CMTS-MAC=34:f8:e7:58:04:e9;CM-QOS=1.1;CM-VER=3.1;
2024-07-04, 20:39:44 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=14:59:c0:f4:12:10;CMTS-MAC=34:f8:e7:58:04:e9;CM-QOS=1.1;CM-VER=3.1;
2024-07-04, 19:43:13 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=14:59:c0:f4:12:10;CMTS-MAC=34:f8:e7:58:04:e9;CM-QOS=1.1;CM-VER=3.1;
2024-07-04, 19:42:47 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=14:59:c0:f4:12:10;CMTS-MAC=34:f8:e7:58:04:e9;CM-QOS=1.1;CM-VER=3.1;
2024-07-04, 19:13:46 Warning (5) Dynamic Range Window violation
2024-07-04, 19:13:46 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=14:59:c0:f4:12:10;CMTS-MAC=34:f8:e7:58:04:e9;CM-QOS=1.1;CM-VER=3.1;
