Tortoises
May 13, 2022Tutor
CM1000 Modem not connecting to ISP
When I turn on my modem the power light turns solid green, then all the lights underneath blink green and then blink amber before all off them turn off and just the bottom light with the 3 squares and...
- May 13, 2022Nevermind I figured it out. My idiot self had the power cable for the modem and another wireless signal thing mixed up and when I switched them it worked. Consider this case solved
May 13, 2022Guru - Experienced User
Disconnect the ISP coax cable from the modem.
Press the reset button in back for 10 seconds, then release.
Does the power LED turn ON and the Download LED blink only with out other LEDs turning on?
Tortoises
May 13, 2022Tutor
Holding the reset with the isp coaxial did not affect the light cycle. After the blinking the ethernet light will be solid amber and then a few seconds later the power will light up solid green and then the cycle resets with just the power being on and then the blinking
