Tortoises's avatar
May 13, 2022
CM1000 Modem not connecting to ISP
When I turn on my modem the power light turns solid green, then all the lights underneath blink green and then blink amber before all off them turn off and just the bottom light with the 3 squares and...
  • Tortoises's avatar
    Tortoises
    May 13, 2022
    Nevermind I figured it out. My idiot self had the power cable for the modem and another wireless signal thing mixed up and when I switched them it worked. Consider this case solved
