pcraft411
Apr 16, 2020Follower
cm1000 modem
I have the netgear cable modem cm1000 and it is located downstairs, i am located upstairs, i have an extender but it is not working as well as i thought, i need to know how can i make my range bette...
Apr 16, 2020Guru - Experienced User
The CM is just a modem only, there is no router or wifi built in. You need a external wifi router to work with the CM modem. NGs R, XR, RAX or Orbi wifi routers would be someting to look at.
