ABusOfNuns
Sep 08, 2018Aspirant
CM1000 multiple unlocked channels, millions of uncorrectable errors after 2 hours
Hello all, I have a CM1000 with Comcast's gigabit tier service. This is the second new CM1000 I've tried and I am still experiencing these issues, so I don't think the modem is at fau...
- Sep 08, 2018
you have an issue with your line. It may be your home wiring or even signal coming in from street.
Do you have any other outlet to connect and check?
vkdelta
Sep 08, 2018NETGEAR Employee Retired
ABusOfNuns
There are other outlets in the house that used to be connected to the main line via splitter, but when we ordered the service, a tech came, removed the splitter, and made a direct connection from the outside line to the outlet the modem was connected to.
I called Comcast and a tech is coming tomorrow, will update on what happens.
