ABusOfNuns's avatar
ABusOfNuns
CM1000 multiple unlocked channels, millions of uncorrectable errors after 2 hours
  Hello all, I have a CM1000 with Comcast's gigabit tier service. This is the second new CM1000 I've tried and I am still experiencing these issues, so I don't think the modem is at fau...
  • vkdelta's avatar
    Sep 08, 2018
    you have an issue with your line. It may be your home wiring or even signal coming in from street.
    Do you have any other outlet to connect and check?
