ABusOfNuns
Sep 08, 2018Aspirant
CM1000 multiple unlocked channels, millions of uncorrectable errors after 2 hours
Hello all, I have a CM1000 with Comcast's gigabit tier service. This is the second new CM1000 I've tried and I am still experiencing these issues, so I don't think the modem is at fau...
- Sep 08, 2018
you have an issue with your line. It may be your home wiring or even signal coming in from street.
Do you have any other outlet to connect and check?
ABusOfNuns
Sep 09, 2018Aspirant
Tech came and opened the wall plate the coax was coming out of. The wiring in there was almost non-existent, and completely frayed. He fixed it, and now there are practically 0 uncorrectable codewords after an hour!
vkdelta
Sep 09, 2018NETGEAR Employee Retired
wow! thank you. Mission accomplished.
There is tiny uncorrectables but not too bad.
