Backintheday
Oct 26, 2021Tutor
Cm1000 need to downgrade firmware from by xfinity to work with wave broadband
How do downgrade firmware? Came from xfinity to wave broadband and waves update fails event log shows it failing wave is on like a v.3.01 and xfinity is on v 7.01
Backintheday
Oct 26, 2021Tutor
Wave broadband has tried to downgrade its firmware but xfinitys update is a high update then wave broadband the modem is not allowing a downgrade firmware should have away to take it to lower firmware. Xfinity is the on a higher update then most if not all other providers
Oct 26, 2021Guru - Experienced User
The firmware is part of the provisioning. When Wave pushes the provisioning, it contains its firmware for their service.
It won't be "blocked" from being downgraded.
Do you have a screen snip of the cable connection page and the event log?
Is the CM1000 compatible with Wave?
- BackinthedayOct 26, 2021TutorWhen I get home I'll pull the logs and current firmware version. And yes its one of the only ones allowed with wave .
