ossy43
Jul 18, 2018Aspirant
CM1000 not connecting at gigabit speeds
I'm having problems with my gigabit connection, I'm just able to get 350 Mbps instead of 900+
I already reset the modem, did factory reset.
Nothing works.
ossy43
Jul 20, 2018Aspirant
RCN in NYC.
Yep according to them I should be getting gigabit speeds. But the max I get is 500mbps.
Connecting direct the modem to my desktop computer using an ASUS XG-C100C 10G Network Adapter PCI-E x4 Card.
vkdelta
Jul 20, 2018NETGEAR Employee Retired
What FW are you on?
this looks could probably be configfile/bootfile or a capacity issue. Have you tried any other RCN supplied modem and recieved close to 800-900 Mbps ?
- ossy43Jul 20, 2018AspirantNope, tried the Arris SB8200 and it was even slower...
- ossy43Jul 20, 2018AspirantI have 3.xxx firmware...
- vkdeltaJul 20, 2018NETGEAR Employee Retired
since you have tried 2 different retail modems from 2 different companies, I would err on it being RCN issue (boot file or capacity/signal issues)
- ossy43Jul 21, 2018Aspirant
Hardware Version 2.02 Firmware Version V3.01.04 Cable Modem Serial Number 4L0483WF01169 CM certificate Installed CM MAC cc:40:d0:25:c1:b0 - ossy43Jul 21, 2018Aspirant
Event logs
- vkdeltaJul 22, 2018NETGEAR Employee Retired
do not see anything wrong in status message.
Only thing remains is the bootfile/config file.
